You Tube Videos
- Re: You Tube Videos
You Tube Videos
21-01-2014 10:20 PM
Also, now when I try to download videos, I cannot do it. Have they somehow managed to lock down these videos? Has my software (whatever I used - Realplayer Free, I think) been updated so it no longer allows me to do that? Can someone recommend software that would allow me to continue to download (legally of course)
Re: You Tube Videos
21-01-2014 10:52 PM
No idea about the video downloads but try keepvid.com
Re: You Tube Videos
22-01-2014 8:24 AM
youtube-dl is another option, if you don't mind the command line. I use a combination of youtube-dl to get the DASH audio and video streams, before muxing them back together with MP4Box.
Re: You Tube Videos
22-01-2014 9:38 AM
I use GOM player which can handle most file types .... to play videos
Re: You Tube Videos
22-01-2014 5:50 PM
Quote from: penneck A few years ago I downloaded some music videos from YouTube (hopefully that's not illegal).
With my pedant's hat on yes it is
It is a breach of Youtube's T&C in that you are only allowed to stream videos, quite apart from whether the videos' themselves are copyrighted.
"You agree not to access Content for any reason other than your personal, non-commercial use solely as intended through and permitted by the normal functionality of the Service, and solely for Streaming. "Streaming" means a contemporaneous digital transmission of the material by YouTube via the Internet to a user operated Internet enabled device in such a manner that the data is intended for real-time viewing and not intended to be downloaded (either permanently or temporarily), copied, stored, or redistributed by the user.
"You shall not copy, reproduce, distribute, transmit, broadcast, display, sell, license, or otherwise exploit any Content for any other purposes without the prior written consent of YouTube or the respective licensors of the Content."
Re: You Tube Videos
22-01-2014 7:42 PM
I use Gom Player, and the video is fast on that. I've gone back to RealPlayer, but that didn't help. Some videos are fine, its just a few that are a problem
Re: You Tube Videos
22-01-2014 7:50 PM
Re: You Tube Videos
22-01-2014 7:52 PM
Re: You Tube Videos
22-01-2014 7:53 PM
Re: You Tube Videos
23-01-2014 7:12 PM
I've tried runing them on Gom, and Realplayer. That makes no difference either.
Shutter, may I have that other Get-out-of-jail-free card too please. I get the feeling I'm going to need a few
Re: You Tube Videos
23-01-2014 7:35 PM
Re: You Tube Videos
23-01-2014 7:42 PM
I use these when VLC and GOM fail to play specific file videos.
Another suggestion when using VLC is to go to the Audio dropdown menu and if there is another audio track listed try that.
Forum Moderator and Customer
Re: You Tube Videos
23-01-2014 8:55 PM
Re: You Tube Videos
24-01-2014 3:53 PM
I tried loading Splash Player Lite to solve my video speed problem, but I didn't like the extra add-ons it was putting, so I cancelled it. I then went into Control Panel/Add-Remove Programs, and uninstalled these add-ons. Now when I reboot, it comes up with "NTLDR is missing Press Cntl Alt Del".
I have booted up from my XP CD, and gone into Repair. I have got past Enter Administrator Password, to where the screen says C:\windows, but when I type in "copy d:\i386\ntldr c:\", it replies Access Denied.
Any suggestions?
Re: You Tube Videos
24-01-2014 4:12 PM
I never had a problem like that when I installed Splash Player Lite. I certainly don't remember it attempting to install lots of junk, either, as I would not have continued with the installation myself. Maybe things have changed as I installed it November 2011.
