Yellow Ethernet Cables & Routers
Lurker
Re: Yellow Ethernet Cables & Routers
No it isn't, the only thing as good as turning it off, is turning it off!
Perhaps a more useful thing to say was nothing at all if you don't know the answer.
You don't have to add a reply to every single post that appears. Grin
pierre_pierre
Right found my CD
Stage one log onto router 192.168.1.1
Configuration
This section lets you configure your BT Voyager 2110 Wireless base station.
You will be prompted to enter a User Name and Password before you can open any of the pages in the Configuration section. By default, both User Name and Password are set to admin
Quick Setup
Wireless
Local Network
Internet
Security
Virtual Server
IP Routing
DNS Server
Quality of Service
IGMP Proxy
Wireless Configuration
Settings
Encryption
MAC Access Control
Repeater
Wireless Settings
Enable Wireless Network
Tick this box to enable your wireless network. When wireless is disabled, the Wireless light on the front of your Voyager router will switch off.
Hope thats OK
Denzil
Quote from: pierre_pierre
... by typing 192.168.1.1 into a web browser address bar, just in case you didn't know.
Interested
Thanks all. Smiley
Everything fine and dandy now.
Wireless disabled, ethernet cable CAT 5e working perfectly. Cool
