Xp start menu
- Xp start menu
Xp start menu
20-11-2008 1:09 PM
My start menu-all programs, has filled up the 2 available columns, and refuses to start another one, the newer programs being hidden. I have partially solved this by using the classic XP start menu, but would prefer to use the standard XP one. Cant seem to find anything in the registry to add a 3rd column, and tweakUI is no help here. I did hear somewhere, that 2 columns is the max, but that seems pretty stupid to me.
Re: Xp start menu
20-11-2008 1:26 PM
Re: Xp start menu
20-11-2008 1:31 PM
Re: Xp start menu
20-11-2008 1:39 PM
Re: Xp start menu
20-11-2008 2:17 PM
Re: Xp start menu
20-11-2008 3:42 PM
Re: Xp start menu
20-11-2008 4:13 PM
To explain a bit more heres a screenshot of the desktop, with the issue arrowed, if it helps
Cheers
Re: Xp start menu
20-11-2008 5:55 PM
Which theme are you using? Not sure if this is why you are seeing things differently?
http://support.microsoft.com/kb/286721/en-us
Jeff
Re: Xp start menu
20-11-2008 6:07 PM
Am using the Royale theme. Its a modified theme from XP MCE. Will try the standard XP theme, see if it goes back to normal.
Cheers
EDIT..... Nope that didnt work
Re: Xp start menu
21-11-2008 4:53 PM
Start > Settings > Taskbar and Start Menu > click on the Start Menu Tab at top
Select "classic start menu" Click "Apply" click "OK"
Re: Xp start menu
21-11-2008 5:01 PM
(b) In reply 1 I pointed out that I am using the normal XP start menu (not Classic) and I have three columns.
Re: Xp start menu
21-11-2008 5:07 PM
Re: Xp start menu
21-11-2008 5:09 PM
Re: Xp start menu
21-11-2008 5:20 PM
Quote from: shutter XP.... the Classic Menu provides smaller columns (I think) as I have it enabled, and there is room for at least three columns, the font is smaller too...
Looking at the screen dump penfold provided he has room for a third column.
Re: Xp start menu
21-11-2008 5:28 PM
Quote from: jelv Looking at the screen dump penfold provided he has room for a third column.
Also, penfold has tried classic menu and says it works but doesn't want to use them:
Quote from: penfold I have partially solved this by using the classic XP start menu, but would prefer to use the standard XP one.
Jeff
