Has anyone else used the Xbox Video store?
My housemate was trying to watch a movie from it but it keeps dropping out saying that he's gone offline.
His Xbox One is hard-wired to the Gigabit switch on the back of one of the Tenda N600/N60's I use as access points (DHCP off, UPNP off uplinked via one of the LAN ports so acting as a dumb unmanaged switch with a wi-fi AP attached)
I do have Netgear GS108e switches at various points in my network and I have one that's currently unused, these support port mirroring so if I really needed to I could shove one between the xbox and the tenda to take a packet capture but I thought I'd check it's not something else before going that far.
