XP - Sata Install problem
I'm trying to install XP Pro SP2c on a new PC with three internal SATA drives.
XP is giving me a hard time, having asked me if I want to create a parition on the target drive it then says it needs to copy some files across but that is can't because the drive doesn't have a valid boot sector for XP.
If I have to I guess I could put a drive in another machine format is and try again. I remember the days when XP didn't recognise SATA drives without extra drivers during install, but surely as it can see all three this isn't the problem any more?
Any ideas for a quick solution?
Fixes: 62
Re: XP - Sata Install problem
I have no direct experience of a multiple sata drive problem but I know that trying to install on a sata drive when there is a PATA drive installed won't work as XP puts some files on the PATA drive even though it isn't supposed to.
Can you try disconnecting the two drives you aren't going to use and trying to install on the remaining one as I suspect it is trying to put some files on one of the other SATA drives
That sounds right Jim. When XP install offers me the drives to install on they all seem to be the same drive number. I was trying not to open the box again but I reckon I will have to! I'll give it a go and report back!
Argghhhh... PC boot now seems to stop during post at ACPI controller. I have no idea what is going on!
Fixes: 62
Which motherboard are you using.
I seem to remember reported problems using the off chip SATA port on some motherboards
Gigabyte GA-P35C-DS3R Socket 775 8 Channel Audio ATX Motherboard
Fixes: 62
first thought is to try using the yellow SATA connector instead of the purple one as the purple one uses the JMicron JMB363 chip while the three yellow ones use the Intel ICH9R Southbridge.
Fixes: 62
Jim,
I think it was two problems. One being the three drives, the other I noticed that the floppy activity light was staying on, once I disconnected the floppy and reduced to one disk it seems happy to install.
I think I have seen this before when a badly connected floppy hangs the system. Which keep the floppy light on power or data cable connected wrongly?
Hi Jim, Yup that is the order I have wired them up, the first three for the sata hard disks,  system on 0 then 4&5 for the dvd drives nothing on six then 7&8 (purple) for the external sata bracket.
Fixes: 62
It's a very long time since I had a problem like that (to give you an idea how far back - it was when you could put IDE cables on the wrong way round  Grin) and I think it is due to the data cable not being fully home so that the system knows it is there and keeps trying to get the correct response and failing.
Plugged in the other Sata drives and all is fine. I will take a look at the floppy tomorrow! Like you I didn't think it was possible to cable a floppy the wrong way anymore! I remember both ends having notches when I fitted it, maybe its a faulty drive.
Fixes: 135
Quote from: God
I was cabling up a PC the other week and when I came to the Floppy I followed convention of pin 1 next door to the power socket. I later discovered it was reversed.
PCs generally don't come with floppy drives these days anyway (no-one needs them any more Undecided) and an external USB device is usually offered.
Customer and Forum Moderator.
Floppies are definately legacy, but some folks need them. This little blighter is a Sony and it turns out the socker had a cut out on top and bottom. There you are then, the lesson is look before it is in the chasis and you can only see one of the notches clearly!  Grin
Thanks for you help folks.
Fixes: 135
I love these PC oddities....
"Try booting from a bootable floppy"  no floppy drive installed.
'Keyboard failure...press f1 to continue' !!!!
'Modem failure....download fresh drivers from the maker's site !!!
