XP IP address Query
- XP IP address Query
- « Previous
- Next »
Re: XP IP address Query
07-06-2010 12:19 PM
I think most of us are probably our own worst enemies, actually. Is that lucky?
07-06-2010 12:21 PM
07-06-2010 12:29 PM
Quote from: ReedRichards Okay, I'm willing to make a small bet that it isn't a fix. By the way, do you have some sort of a nickname, 'A Fox ...'. I find the full name a bit too much to type.
An anagram of "a fox is evil" is "axisofevil"
If you are not your own worst enemy, it means that someone else is.
07-06-2010 12:40 PM
Bumbershoot, I don't think you have ever really explained your criteria for deciding whether the connection is working or not. Do you see a cross or an exclamation mark against the wireless icon on the task bar? Or do you just try to connect to a web site and get a browser error message?
07-06-2010 12:46 PM
Quote from: A An anagram of "a fox is evil" is "axisofevil"
I noticed you changed your name a while back. I could call you Jeremy, would that be okay? It looks like I won that small bet; what did I win?
Quote from: A If you are not your own worst enemy, it means that someone else is.
But then it really depends on whether somebody else would do a better job of being your enemy than you would yourself?
07-06-2010 1:27 PM
Why don't you call him Bruce - just to avoid confusion.
07-06-2010 1:33 PM
Would buying a wireless pci card help.
My criteria for deciding the connection is not working is windows telling me I have limited or no connectivity and when I hover the curser over the green box showing the signal strength the address is shown as 0.0.0.0.0
07-06-2010 1:50 PM
I don't see that a PCI card is any better than just buying another USB adaptor, you should be able to get one for around £20.
07-06-2010 2:41 PM
Quote from: ReedRichards I don't see that a PCI card is any better than just buying another USB adaptor, you should be able to get one for around £20.
PCI every time, if you can.
(similar price)
There are SOME reasonably good USB units and many indifferent ones.
Personally I'd go for a PCI device with a separate desktop aerial on a reasonable length of lead.
e.g. : EdiMax EW-7128g
(available widely, £10 to £15 on Amazon for example)
07-06-2010 4:30 PM
Quote from: bumbershoot My criteria for deciding the connection is not working is windows telling me I have limited or no connectivity and when I hover the curser over the green box showing the signal strength the address is shown as 0.0.0.0.0
I got that with a PCI Wireless card - but the DNS fix fixed it for me.
Quote from: ReedRichards I could call you Jeremy, would that be okay? It looks like I won that small bet; what did I win?
That would be fine.
Quote from: A I'm willing to make a small bet that this is a fix
Sorry
I didn't actually make any bet...
BTW a PCI connection is connected directly to your main data bus; USB is an extra layer of complexity.
Go for PCI every time - you will need to open the box though and permanently install it.
07-06-2010 7:19 PM
Jeremy's problem was a consistent failure. Software is pretty good at consistency. Bumbershoot's problem is inconsistent; sometimes it works sometimes it doesn't. I think that is much more likely to be down to a hardware problem, although it could be some other external factor.
- « Previous
- Next »
