XBOX and PC sharing speakers, any risk of damage?
Hi Folks
I have a set of Logitech Z2300 200W 2.1 speakers that I use for my PC and I also want to connect my XBOX to them as well.
I have worked out adapters so that both the PC and the XBOX can be connected to the speakers at the SAME time.
Not being an electronics buff and not wanting to blow my PC sound card or the XBOX I have a very basic question before going live with the system:
I am assuming that the sound outputs from the PC and the XBOX put out fairly low voltages, but as both outputs will effectively be connected to each other as well as the speakers is there any possibility they will cause damage to either device?
I am trying to get them to share so I don’t have to swap the speakers between devices each time I use them.
Cheers
scootie
Re: XBOX and PC sharing speakers, any risk of damage?
if there will be any damage it will most likely happen at the amp input ,if you have both sources in use at the same time then your likely to run in to trouble but if you insure only one source is ever used at any one time then no damage should occur.
i have a double input setup like yours, but i have 3 of these http://www.audiogear.com/cgi-bin/shopper.cgi?preadd=action&key=ADPT2RCFMSM&reference=/cgi-bin/shoppe... and the double female ended connectors so that i can leave one in the amp and leave the other 2 connected to my pc and xbox (tv output as i run on hdmi cable) and then its a quick job of plugging the source into the double ended female connector on the amp input one, so no need to break my back hunting for the green output on my sound card each time i swap
EDIT. sorry i have i got these http://www.audiogear.com/cgi-bin/shopper.cgi?preadd=action&key=ADPT2RCM2RCM1M&reference=/cgi-bin/sho... in the amp input and no longer need the double female ended connecters that was an old setup
am sure there is some equipment out there that removes the need to do it like this or the workaround your using but all my life i have had loads of these audio cables and connectors so its just the way i do it with out blowing the cob web's off me wallet
Thanks for the info. I guess I will just keep the double connector on the desktop and remember to disconnect one, I had hoped the two sets of signal were treated as parallel rather than in sequence (to use a battery  analogy), ah well, never mind.
I have tons of connectors and cables as well. Folks think I am mad to hoard them all, until they say have you got something to do this and it is instantly produced from the cable draw!
scootie
watch this from 1 min 30
VileReynard
Seasoned Pro
Fixes: 11
Assuming that you don't want to output from both devices simultaneously,
Why not just get yourself a 2way double pole (like a mains voltage A-B) switch?
I once had a 100W (rms) amplifier and I used this method to switch the output between two pairs of 50W speakers.
Fixes: 131
Something like this http://www.maplin.co.uk/Module.aspx?ModuleNo=23189
Customer and Forum Moderator.
Ah I see!
Presumably this little puppy would do the trick then? http://bit.ly/8YZPyQ
Fixes: 131
Even better Smiley
Thanks to all for your help.
