Would you buy a new PC with only a SATA 1 interface
Fixes: 57
http://forums.macrumors.com/showthread.php?s=af3b1e4cf0748eaf2da52ea061114d44&t=718516
It looks as though a number of Macnook Pro owners have done just that and are not entirely happy when they slot a SSD drive in to find the data rate is severely limited
1 REPLY
Fixes: 113
Re: Would you buy a new PC with only a SATA 1 interface
It's not a SATA1 infterface, just limited to 1.5Gbps throughput - probably for power saving reasons - I believe
Levono did the same with their thinkpads.
Will Moderate For Thanks
