Worth replacing the Technicolor TG582n with newer Sagemcom 2704N??
weirdgeordie
I've currently got the Technicolor TG582n on a 80/20 fibre service, I've had no end of problems with the router with port routing for gaming and torrents, the UPnP is terrible.
The wi-fi isn't great either, with some devices not even using the DNS routing properly.
What are people's experiences with the Sagemcom 2704N for things like UPnP and console gaming? Worth me renewing my contract to get one?
My actual fibre service is actually very good, I get 75mbps+ on a good day,  but I'm right beside the cabinet, which probably helps.
I'd be really grateful for some advice Smiley
Thanks!
James
6 REPLIES 6
Oldjim
Resting Legend
Fixes: 63
Re: Worth replacing the Technicolor TG582n with newer Sagemcom 2704N??
My suggestion - buy a decent one and forget about the Plusnet freebies
Fixes: 1,483
port forwarding is worse on the 2704N.. go with OJ's suggestion.
weirdgeordie
I suspected that might be the suggestion (To buy my own) . .
What are the BT Home Hubs like? You can get them cheap on eBay, anyone have experience with them?
chenks76
All Star
Fixes: 12
you can get v4 models cheap, not sure about v5 ones though.
and it's a v5 one you'd want.
nanotm
whatever you buy make sure its ipv6 capable or next year it will need replacing again ....
weirdgeordie
Thanks for the advice - greatly appreciated Smiley
