Worm spreading amongst routers running Linux
techguy
MrC
Re: Worm spreading amongst routers running Linux
As usual El Reg is ever so slightly exaggerating things here for the sake of a good story.
If you actually read the linked PDF the vulnerability currently only affects one model of router (Netcomm NB5) and then only those with early firmware. Plus the infection rate as reported isn't huge.
Mike
Lurker
And it relies on weak passwords...
Fixes: 114
So all in all nothing to worry about at all...  Roll eyes
Will Moderate For Thanks
Lurker
Might be interesting in years to come as a bit of trivia though...
/files in memory bank...
