Word to PDF to Kindle
Fixes: 9
Is it possible to download something into word, convert it to PDF and then transfer it to your Kindle ?
Waldo
Re: Word to PDF to Kindle
Connect the kindle to your PC via USB and it'll show up as a mass storage device in your file manager; drag and drop the PDF into the Documents folder on the kindle.
But that doesn't convert the Word document to PDF.  There are a number of online routes to convert Word to PDF.
VileReynard
All Star
Fixes: 11
There are many e-reader style tablet style formats.
If you are unlucky, you are using the betamax version.
The kindle uses a propriety format...
http://en.wikipedia.org/wiki/Comparison_of_e-book_formats#Supporting_platforms
Waldo
Quote from: hulls
I don't use Word (or Windows); I'd use the 'export as PDF' option in LibreOffice.
If Word doesn't have something similar I guess the likes of doPDF which installs as a virtual printer driver should work for every application which has a print function.
You don't need any of that, Amazon does it for you.  Cool
RTFM as they say.  Wink
Just email a word document as an attachment to the kindle. It will be converted automatically (as are many formats).
Free Transfer of Personal Documents
If you would like to transfer your personal documents to your Kindle for free, you can send attachments to "name"@free.kindle.com to be converted and e-mailed to your computer at the e-mail address associated with your Amazon.co.uk account log-in. You can then transfer the document to your Kindle using your USB connection.
For example, if your Kindle e-mail address is Jay@Kindle.com, send your attachments to Jay@free.kindle.com.
Fixes: 9
HPsauce,
I Think your answer is the best and easiest solution.
I'm also pretty sure you can email documents directly to the Kindle bypassing the PC connection as long as it's WiFi connected.
(sure I did that to SWMBO's not long ago, just can't recall the detail, but it was pretty simple)
Edit.
Yes, just use the email method and "approve" the sending email address in your Kindle account (required whatever transfer method you use) then connect your Kindle to t'internet via WiFi and the document automagically arrives.
Simples!  Grin Grin Grin
