Word Macro's can infect your machine
Oldjim
Fixes: 63
http://www.theregister.co.uk/2016/11/01/nymaim_malware_got_a_major_upgrade_says_verint/
So I thought I would check the Word Security Settings
Looks OK
So what are the Trusted Sources
Bloody hell - who made those trusted
This is one source http://download.cnet.com/windows/detong-technology/3260-20_4-10098037-1.html so will now see what I installed from Wondershare - seems to be a program for connecting my better half's mobile to the computer which didn't work - cheeky sods as I uninstalled it
4 REPLIES 4
ReedRichards
Seasoned Pro
Fixes: 25
Re: Word Macro's can infect your machine
No Trusted Publishers for me.
Oldjim
Fixes: 63
Just removed them all and spent a further 10 minutes removing Wonderware from the Registry as it had got its claws in all over the place
Even then I had to delete two services using an elevated command prompt
alanf
In MS Office I had Hewlett Packard, Symantec and Verisign as Trusted. (an HP computer with Norton Security installed).
These days my default choice is LibreOffice and I have nothing trusted in that.
rongtw
Fixes: 12
LibreOffice for me to Thumbs_Up
