With regret
Fixes: 388
Re: With regret
@rooky wrote:
Refresh me how to find the stats
For the Hub One -
For the Hub Two -
Just long enough to obtain the data.
Fixes: 585
Re: With regret
Just long enough to get the stats. TBH I don't use a PN supplied router but there's plenty of posts on here showing how to get the stats
Thanks @jab1
rooky
Re: With regret
If just looked no longer got my plusnet router arghhhhh
rooky
Re: With regret
Well i just found it remember where i put it
Product code:Plusnet Hub Two
Serial number:+108417+2134006714
Firmware version:v0.10.00.04201-PN
Firmware updated:19-Jun-2023
Board version:R01
GUI version:1.9 16_08_2022
DSL uptime:0 Days 0 Hrs 1 Min
Data rate:17 Mbps / 66.999 Mbps
Maximum data rate:21.664 Mbps / 73.140 Mbps
Noise margin:9.1 / 7.2
Line attenuation:7.2 / 14.3
Signal attenuation:7.1 / 14.4
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:-
outcast
Aspiring Champion
Fixes: 19
Re: With regret
Banded line !  -  needs a DLM reset !
rooky
Re: With regret
what
Fixes: 388
Re: With regret
Looking at that, @rooky , you should get roughly your old speed - the downstream SNR is a tad high,  but that could be due to a solvable issue in the OR network.
I'll leave it to @MisterW to correct me if I'm wrong.
outcast
Aspiring Champion
Fixes: 19
Re: With regret
Openreach DLM has slightly speed restricted your connection
Your Data Rate should be nearer 20/73 Mbps,  if it wasn't clamped.
Fixes: 388
Re: With regret
@outcast the thought did occur to me, but if @rooky moved, it would be done anyway.
rooky
Re: With regret
Well look like i have to move Sky just wont do anything anymore they said open reach done what they can and sky wont do anything at all.. I hope moving back to plus net and plus net will get it all sorted for me
rooky
Re: With regret
This meaning Open Reach have messed me up
Fixes: 388
Re: With regret
Just be aware you won't have a landline phone if that is important to you.
rooky
Re: With regret
Nope never used a Land line phone for years..
rooky
Re: With regret
Are we all saying if i move back Plus Net will get me back to how i was?  Why has open reach messed my connection up with sky then?
Fixes: 388
Re: With regret
It may not be OR that has 'messed your connection up' - possibly incompetence/lack of will on behalf of SKY.
