Wireless showing connected but no web page displayed
- Wireless showing connected but no web page display...
24-08-2010 2:58 PM
I've installed a netgear dongle WG111T on my PC.
It shows connected on the system tray and in the wireless lists etc but when I try opening a web page it does not open.
(Usual error message is displayed about no connection)
I am obviously missing something simple (I don't mean a brain) but I can't work this one out.
All help most welcome
3 REPLIES 3
Re: Wireless showing connected but no web page displayed
24-08-2010 3:31 PM
What happens if you open your web browser and type in the IP address of your router (for example "192.168.1.1") into the address bar where you would normally type "www...." ?
Do you get the router's login or status page displayed ?
24-08-2010 3:37 PM
Can you also open a DOS command window, type "ipconfig /all" <Enter>, and post the results back in this thread.
24-08-2010 4:58 PM
I'll get back to you on this because the PC has just been taken off site.....
Thanks for your help....
