Wireless security
bumbershoot
Wireless security
Hi,new to wireless.Do I need to change the router user from admin to another name or is my broadband protected enough by the wireless key?
Fixes: 133
Re: Wireless security
A good strong admin password will help prevent unauthorised access to your router.
Customer and Forum Moderator.
greyposter
How would I do that,please ?
pierre_pierre
What router?
greyposter
Thomson TG 585v7
pierre_pierre
bumbershoot
Hi,very confused.Can I change the router user from "admin" to another word or is it the password that can be changed, named as "wireless key" on the setup sticker,Ten figures,a mix of numbers and letters, as suplied with the tompson router.Thanks
pierre_pierre
yes you can change the name and its password, the other item I would think is the WPA pass
Denzil
In other words, you have an admin username and password which allows you to access the router's settings. The wireless key is a separate password that PCs use to connect wirelessly to the router for normal internet access.
