Wireless printer connection problem
glennpj373
Hi, I transferred from pipex to plusnet last week and have since then been unable to re-connect my wireless printer, which is an HP Photosmart C4585.  Can anyone help as my IT skills are very limited!!!
Re: Wireless printer connection problem
Not sure if it's relevant (different printer and different router), when I recently changed routers i had to reinstall the driver software to get the router to work by wireless on the new router.
jojopillo
HI glennpj373,
what router is it?
Jojo Smiley
