Wireless networking
weatherman
Wireless networking
I have a Asus A8V delux M/B and a Netgear router it did work but for some reason has stopped, so at present I have to hard wire it and it works fine but I would like the added flexability of the wireless has anybody got any ideas as to how you get the wireless motherboard and the router to speak to each other?
VileReynard
Seasoned Pro
Fixes: 11
Re: Wireless networking
Have you tried "Broadcast ssid in the router"?
weatherman
It is set to broadcast ssid
weatherman
Can you give some more details about your problem? Is Windows able to search for wireless networks and recognise the SSID of your network? :t shows Netgear router in connect to
How are you trying to connect, through the ASUS software or the zero config wizard?, :not sure what the zero config wizard is
What version of Windows (or other operating system) are you using?: Windows XP Prof SP2
Does the wireless adaptor appear in Device Manager? :hopefully the screen dump has got through
VileReynard
Seasoned Pro
Fixes: 11
The main PC's are Linux (Ubuntu) - although I do have a laptop which runs Windows XP SP2.
The router is Netgear and I have 2 PC's on Ubuntu (Dapper) + one PC on Ubuntu (Feisty).
AFAIK all 4 PC's have Netgear cards and the wireless router is also netgear.
I can display several Wireless networks from the Windows machine, even when my main PC indicates that signal strength is low. (Re)-connection has always been possible - although it sometimes takes a very long time.
Current (moderate) Linux details are [**** = pathetic attempt to hide security]
I have always had broadcast SSID switched on - I think Windows couldn't connect without it (not sure about that...).
Distance from this PC to router is about 5m including a brick wall.
Details of PC Wireless card [on LAN]:- iwconfig ath0
ath0  IEEE 802.11g  ESSID:"*****"  Nickname:""
          Mode:Managed  Frequency:2.437 GHz  Access Point: [MAC-ADDRESS****]
          Bit Rate=12 Mb/s  Tx-Power:18 dBm  Sensitivity=0/3
          RetryShockedff  RTS thrShockedff  Fragment thrShockedff
          Power ManagementShockedff
          Link Quality=21/94  Signal level=-74 dBm  Noise level=-95 dBm
          Rx invalid nwid:0  Rx invalid crypt:0  Rx invalid frag:0
          Tx excessive retries:0  Invalid misc:0  Missed beacon:0
VileReynard
Seasoned Pro
Fixes: 11
Oops I posted in the wrong thread - sorry Cry Cry Cry
weatherman
I have tried the action you suggested but still get no wireless connection I have downloaded Network Magic but this doesn't help there must be something simple I am not doing right as it all used to work
Will
This happens to me from time to time when i change router settings.
I find simply resetting the router to factory defaults sorts it out.
VileReynard
Seasoned Pro
Fixes: 11
Have you tried PJ's suggestion of
If you live in a suburban area you should be able to find several networks, especially around teatime.
