Wireless connection unreliable
- Re:Wireless connection unreliable
21-10-2009 10:20 PM
Hi all, I have a Belkin ADSL2 + modem with wireless G plus MIMO router model F5D9630 which was working fine until just recently. To connect wirelessly I have to go to services to start the windows XP wireless zero config & this is ok until I shut down & reboot & I have to carry out the same performance to connect each time. I have a choice to use the Belkin utility or the standard windows utility to control the wireless connection & have used both at different times but I still have to start the WZC. I have done a connectivity test results as follows: Loopback, IP, Gateway, DNS, Heartbeat, Belkin, Yahoo, all passes, WAN- Fail.
I have contacted Belkin support & cannot get a satisfactory answer to the problem, I have tried resetting to factory settings checked that all the info I've used is correct & it is, contacted PN support who tell me to unplug the device for 15 mins (sounds all too familiar!) Checked the device manager which tells me the device is working ok. I suspect a setting must be wrong but don't know enough to be sure. I can connect with ethernet cable but daughter need the wireless connection for her laptop. It takes an age to load web pages as well but I'm not sure if this has a bearing on the problem. Hope this is enough info for someone to hopefully give me a clue as to what the problem is.
6 REPLIES 6
Re: Wireless connection unreliable
21-10-2009 10:56 PM
looks like the wireless utility is disabling WZC on startup.
you might have tried this but give it a go if not:
does the utility start when windows starts (listed on the startup tab on msconfig.exe)?
1. disable the utility from starting with windows
2. set the WZC to automatic start instead of manual start
reboot and use the standard windows wireless tool to check.
21-10-2009 11:49 PM
Hi thanks for your reply,
Sorry to sound dumb but how do I do that?
Quote from: RamiDoodle
22-10-2009 10:29 AM
You need to go to services.msc and then choose Wireless zero config >> properties >> startup - automatic.
22-10-2009 2:55 PM
Hi Mand,
I have carried out the steps 1 & 2 no problem but what does ramidoodle mean by use the standard window wireless tool to check. Where do I find the tool & what am I checking?
Am I being thick........... do I need to activate the WZC as well as using the Belkin utility to control the wireless connection or choose one or the other.
22-10-2009 3:52 PM
this on vista. go to start menu and connect to
EDIT. sorry didnt see the OP was on xp.
added 2nd pic of xp.
right click the circled icon in the task bar and pick view wireless networks ( this is the default wireless app on xp and needs the wzc service to be running)
22-10-2009 4:48 PM
This is okay until I shut down & I have to start the WZC manually when I reboot even thought it's set for automatic, not too much of a problem for me but it is for the rest of the family it seems, any other ideas as to why this should be happening, has anyone else out there got the same router?
