Wireless and Snow Leopard problems
TomP
Hi all,
Just upgraded to Snow Leopard and suddenly my wireless has stopped working.  I had issues with holding a wireless connection before but the firmware update seemed to fix it.  Now I have upgraded I now get the normal airport signal but with an '!' over it telling me my internet isn't working.  Works fine by the wire but not via wireless.
Running a Macbook and a BT Voyager 2110
Thanks in advance
Tom
1 REPLY
TomP
Re: Wireless and Snow Leopard problems
Problem resolved, needed to enter the DNS servers manually.
