Wireless and Snow Leopard problems
- Wireless and Snow Leopard problems
01-09-2009 6:15 PM
Hi all,
Just upgraded to Snow Leopard and suddenly my wireless has stopped working. I had issues with holding a wireless connection before but the firmware update seemed to fix it. Now I have upgraded I now get the normal airport signal but with an '!' over it telling me my internet isn't working. Works fine by the wire but not via wireless.
Running a Macbook and a BT Voyager 2110
Thanks in advance
Tom
Thanks in advance
Tom
1 REPLY 1
Re: Wireless and Snow Leopard problems
09-09-2009 12:55 PM
Problem resolved, needed to enter the DNS servers manually.
