Wireless adaptor
- Re: Wireless adaptor
Wireless adaptor
19-05-2010 2:25 PM
I have plus.net broadband with the Thomson Gateway as supplied by Plus.Net. I have another PC in a different room which doesn't have a wireless facility. Is there a usb type plug in which would enable my other PC to connect wirelessly to my Thomson Gateway.
Cheers
Geoff
19-05-2010 2:40 PM
Have a look here http://www.aria.co.uk/Products/Network+Products/Wireless/Adapter+-+USB/?x=12&p_order=price_asc&p=cF9...
or here http://www.amazon.co.uk/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=usb+wireless&x=0&y=0
Shout up with any more questions.
19-05-2010 3:36 PM
I have a USB wireless dongle (Edimax) that I tried on my friend's machine which was upstairs - router downstairs. Signal was not strong enough so had to abandon it.
On the other hand, it works very well on another friend's desktop but she lives in a small bungalow and the distance between it and the router is very short indeed.
A better solution is an internal wireless card. Last time I fitted one I used a Linksys and it cost about £14.99 from Amazon. It was easy to install (it must be if I can manage it).
19-05-2010 3:46 PM
Cheers again
Geoff
26-05-2010 9:57 AM
I ended up getting a Mini usb wireless dongle from ebay. Works super. Thanks again for the help.
geoff
26-05-2010 11:44 AM
29-05-2010 8:06 AM
Cheers again
Geoff
29-05-2010 9:34 AM
Glad that yours is working well.
29-05-2010 11:29 AM
(haven`t tried it, but I think the video shows it works ! ! )
http://www.wonderhowto.com/how-to-hack-wifi-usb-adapter-better-reception-210506/
29-05-2010 1:30 PM
(Poppy goes off to raid kitchen cupboard!).
29-05-2010 2:44 PM
think the strainer gave a 1/4 more ap's and the bake bean tins was picking up ap's a few streets away but could only see one ap at a time
