Wireless Virgin
pablof79
Wireless Virgin
Hi everyone
I am looking to get wireless internet set up...
I have the plus net £9.99 broadband currently running and wondered if this was ok to use with the wireless router?
Sam
1 REPLY
Re: Wireless Virgin
You can use whatever equipment you like on your broadband connection. PN do not impose any restrictions regarding hardware so you are fine to use a wireless router.
A word of warning though. When you set it all up, make sure you use encryption on the connection WEP or WSK and 128bit to stop others piggy-backing on your connection. Given your product peak time limits it would not take someone very long to exceed them.
