Wireless Query
- Wireless Query
Wireless Query
14-06-2009 10:27 PM
Previously I had a Desktop which was connected
to a THOMSON TG585 v7 wireless router via
an ethernet cable - I'didn't use the wireless connection.
Now I've bought a portable - a Dell Inspiron1545 -
which has a Dell Wireless 1397 Mini Card (802.11 b/g).
My question is will this Mini Card work with the Thompson
router or do I need to buy a wireless card?
Many Thanks for any help
2 REPLIES 2
Re: Wireless Query
14-06-2009 10:33 PM
should do, on the bottom of the router is printed it WPA security code, set this into your PC - all uppercase and it should connect OK, but it is slightly slower than ethernet
Re: Wireless Query
15-06-2009 10:14 AM
Thanks Pierre will try what you say
