Wireless Modem update software
Hi there
I own a USR 9110 wireless modem and very good it is too.
On the USR site it says I am running on the original software and that a flash update is available.
What is the advantage of upgrading?
The device connects well and does the job for which it was designed, so why upgrade?Huh
Many thanks in advance
SG
2 REPLIES 2
Re: Wireless Modem update software
Wise man say: If it ain't broke, don't fix it!
Have you had a look on their website?  Do they give any details of what benefits it could give you?
most router/modem updates just now are fixing bugs, connectivity issues and setting them up to use the new upcoming ADSL2+ and the current draft of N rated wireless devices.
