Wireless Lan Adaptor for Blue Ray player
- Re: Wireless Lan Adaptor for Blue Ray player
27-09-2010 5:11 PM
Buying a Blue Ray Player that has wifi connection...says i need a wireless lan adapter to access online TV/Facebook etc...anyone know will the Router i'm using from PlusNet the Thompson TG585 V7 be compatible ?
Edit: this is what i was looking at
http://skinflint.co.uk/a421871.html
Don't think i explained very well above A friend has a Netgear router and when they use the adapter on the player the wireless connection on their laptops keeps dropping...was wondering if somehow the adapter could be interfering with the Netgear router!
3 REPLIES 3
13-10-2010 5:19 PM
HI jen,
There's no reason why your wireless adapter won't work with the thomson, we don't have problems with PC's using them or indeed the likes of xbox, ps3 and ipod etc.
Jojo
Jojo
13-10-2010 6:23 PM
It's a little more than a wireless adaptor but I use the exact same unit on my Samsung TV with no problems.
Just needs configuring on-screen to connect to your router.
03-11-2010 11:06 PM
Ok...thanks...I've tried on and off for the last couple of weeks and just can't get this to recognise the wireless signal.
Exchanged the adapter thinking it was faulty but no go !!!
Given up on the wireless connection now so just run a 'wired' connection from router to player whenever connections wanted.
