Wired + Wireless connection to Router
- Wired + Wireless connection to Router
11-09-2009 10:57 PM
If I disable either I can still browse internet.
Thank in advance.
Re: Wired + Wireless connection to Router
11-09-2009 11:17 PM
Neither wired or wireless connects to the internet - they both connect to the router.
The router connects to the internet (via the telephone cable).
11-09-2009 11:23 PM
Perhaps what I should have asked is which connection is actually used to the router when this connects to the internet. Is it both, the fastest, the slowest etc.
I am concerned that the 'best' connection might not be being used.
11-09-2009 11:30 PM
For gaming wireless will probably add 2-3 ms to your ping times...
11-09-2009 11:33 PM
11-09-2009 11:42 PM
12-09-2009 11:45 AM
Quote I need to have a wireless connection for a wireless printer.
No you don't, your printer connects wirelessly to the router. Your PC communicates to the printer via the router, so even if you only have a wired connection to the router you will still be able to communicate with the printer.
12-09-2009 12:06 PM
12-09-2009 5:49 PM
The printer is a Canon MP620 (multifunctional device). I'm having issues with this at the moment in that connection is lost after 10 minutes or so, but that's another problem! I could connect via USB but I need to connect it wirelessly to my son's PC anyway.
Thanks everyone.
12-09-2009 6:17 PM
Of course the printer PC would have to be switched on for this work...
12-09-2009 9:54 PM
Quote from: Crucibleofevil If your PC has a choice, wired is [almost] always fastest - but since wired and wireless are both faster than your internet connection
That might not be necessarily true if using ADSL2+ or cable connections and 802.11a/g wireless. The headline 802.11 rates are raw rates (eg no allowance for framing, preamble, CSMA/CA, IP or TCP overhead) in one direction only, and real-world throughputs will be much slower. I've known a single TCP stream to struggle to get near 8Mbps on 802.11g even with clear line-of-sight between client and AP. Any other networks in the area, or more than one client on the WLAN, or any number of other possible causes, can cause WLAN throughput performance to suffer.
And that's before you start considering things like poor USB adapter or device performance, and different 802.11 vendor implementations.
Basically if you want to make the best of a good ADSL2+ or cable connection and wireless, don't use 802.11g but move straight to proper dual-band 802.11n. Better still use a network cable which simply doesn't suffer from many of the things that affect wireless
