Windscribe VPN...
Mav
Fixes: 518
Windscribe VPN...
In my search for a decent VPN for occasional use I tested a few including some mentioned in these forums then came across Windscribe.
With 10GB a month usage on the free account it is more than enough for me plus you can install extensions for FF, Chrome, etc which effectively lets you use the VPN for those browsers activated while everything else uses the normal route to access the internet. Or you can use the Windows app which tunnels everything globally.
I did have a small issue in setting it up but a message to their ticket system was replied to less than 30 minutes later with excellent advice/support.
Perhaps there are other VPNs that are just as good or better but I thought I would share my experience.
Forum Moderator and Customer
