Windows updates
petlew
Windows updates
For the last dozen or so shut downs I have been getting the usual "Update" indicator in the "shut down" button. On inspection it seems Windows wants me to download an Internet Explorer 11 update at 36Mb.
I don't use Internet Explorer, although I realise it exists on my PC. But I have no interest in updating it
It seems its going to keep on offering this update until I do something about it but, I can find no way of declining this update. Un-ticking it in control panel doesn't work as it immediately re-ticks itself.
How can I stop this annoying situation and not have the update, or am I going to have to download it anyway?
12 REPLIES 12
Strat
Fixes: 565
Re: Windows updates
The problem is IE is used not just for browsing.
Skype, for example uses it as I found to my cost when an update broke my IE and took Skype down with it.
I currently have IE9 and regularly refuse an update to IE11.
Just checked and I have IE10 and IE11 waiting to be installed on Windows Update but are unticked and remain so.
RPMozley
Fixes: 13
Re: Windows updates
Right click on the update in the list and choose to ignore it (in Vista & 7). Not checked if this works for that particular update in question but can't help to try it.
That's RPM to you!!
HPsauce
Re: Windows updates
Nothing wrong with IE11, why not let it install?
As it happens my W7 system is still on IE10. I have deferred installing it for now for my own specific technical reasons. If yours won't defer you may hove some other system problems to resolve?
PS If you open IE then open the Help, About box there's an "automatic update" box you can untick.  Wink
artmo
Aspiring Champion
Re: Windows updates
I have W7 and am told it is up to date. Shows the last update was on 29th November.  Is this right?
HPsauce
Re: Windows updates
Depends what it was. My last "major" update was more than 2 weeks before that. Expecting another batch next week.
artmo
Aspiring Champion
Re: Windows updates
W7 is new on this PC so I was making sure everything was up to date.  I just thought there may have been more since then but you've put my mind at rest. Thank you.
HPsauce
Re: Windows updates
Microsoft normally only issue updates monthly, on "Patch Tuesday". http://en.wikipedia.org/wiki/Patch_Tuesday
artmo
Aspiring Champion
Re: Windows updates
Thanks again for the info. I was unaware updates were generally only done once a month.
Strat
Fixes: 565
Re: Windows updates
Quote from: HPsauce
I won't let it or IE10 install because then Skype will not work on my PC.
I have tried all the solutions available except a trash and reinstall of windows.
It works under IE9.
computing50yrs
Re: Windows updates
Well I have IE11 installed and use Skype as well with no problems,  I have latest version of Skype which is 6.11.60.102 so maybe that why Skype fails if using earlier version
Only problem I had with IE11 is the PlusNet Assist as they haven't updated it for IE11 so says its not compatible see my other posting
HPsauce
Re: Windows updates
Quote from: Strat
Not a problem I've seen and PC support is what I do for a living, so it sounds fairly specific to your system.
For @Petlew (the OP) it's a low risk; may not even use Skype.
Strat
Fixes: 565
Re: Windows updates
Others have come across the issue and various solutions (including one from Microsoft) tried with varying results.
In my case I believe an OS reinstall is the way forward and needed anyway to get rid of garbage.
