Windows updates
- Windows updates
Windows updates
06-12-2013 9:19 PM
I don't use Internet Explorer, although I realise it exists on my PC. But I have no interest in updating it
It seems its going to keep on offering this update until I do something about it but, I can find no way of declining this update. Un-ticking it in control panel doesn't work as it immediately re-ticks itself.
How can I stop this annoying situation and not have the update, or am I going to have to download it anyway?
Re: Windows updates
06-12-2013 9:23 PM
Skype, for example uses it as I found to my cost when an update broke my IE and took Skype down with it.
I currently have IE9 and regularly refuse an update to IE11.
Just checked and I have IE10 and IE11 waiting to be installed on Windows Update but are unticked and remain so.
Re: Windows updates
06-12-2013 10:20 PM
Re: Windows updates
06-12-2013 10:23 PM
As it happens my W7 system is still on IE10. I have deferred installing it for now for my own specific technical reasons. If yours won't defer you may hove some other system problems to resolve?
PS If you open IE then open the Help, About box there's an "automatic update" box you can untick.
Re: Windows updates
06-12-2013 10:24 PM
Re: Windows updates
06-12-2013 10:27 PM
Re: Windows updates
06-12-2013 10:46 PM
Re: Windows updates
06-12-2013 11:04 PM
Re: Windows updates
07-12-2013 6:23 AM
Re: Windows updates
07-12-2013 8:26 AM
Quote from: HPsauce Nothing wrong with IE11, why not let it install?
I won't let it or IE10 install because then Skype will not work on my PC.
I have tried all the solutions available except a trash and reinstall of windows.
It works under IE9.
Re: Windows updates
07-12-2013 11:41 AM
Only problem I had with IE11 is the PlusNet Assist as they haven't updated it for IE11 so says its not compatible see my other posting
Re: Windows updates
07-12-2013 11:43 AM
Quote from: Strat I won't let it or IE10 install because then Skype will not work on my PC.
Not a problem I've seen and PC support is what I do for a living, so it sounds fairly specific to your system.
For @Petlew (the OP) it's a low risk; may not even use Skype.
Re: Windows updates
07-12-2013 9:22 PM
In my case I believe an OS reinstall is the way forward and needed anyway to get rid of garbage.
