Windows update KB3024777
- Windows update KB3024777
28-12-2014 10:36 PM
After several attempts today to install KB3024777 I decided to do a google search on the issue and found this.
I have KB3004394 installed but I cannot hide BK3024777. The update is greyed out and can't be unticked as is the option to hide it (W7 Pro 64)
Anyone else experiencing this?
Quote Installing KB302477 will uninstall KB3004394. If you've already uninstalled KB3004394, feel free to hide KB302477 & move on with your life.
Forum Moderator and Customer
2 REPLIES 2
Re: Windows update KB3024777
28-12-2014 10:42 PM
Here's what MS say about these updates!
Geoff,
York.
York.
29-12-2014 2:27 PM
I had the same issue as you Mav, the update was failing every time I tried. I manually removed KB3004394 using add/remove and voila, no issues since.
