Windows giant warns security flaw exploited in wild, but no patch available
- Windows giant warns security flaw exploited in wil...
30-03-2014 5:34 PM
[quote= http://www.theregister.co.uk/2014/03/24/microsoft_rtf_vuln/]Microsoft has warned its Word software is vulnerable to a newly discovered dangerous bug – which is being exploited right now in "limited, targeted attacks" in the wild. There is no patch available at this time.
7 REPLIES 7
Re: Windows giant warns security flaw exploited in wild, but no patch available
30-03-2014 5:49 PM
And later this "fix it" was made available: http://support.microsoft.com/kb/2953095
Usually the "fix it" things involve disabling the affected component, in this case, it will "Disable opening RTF content in Microsoft Word". I doubt many people will care about not being able to open .rtf files.
30-03-2014 6:04 PM
It is a workaround until they make a fix
Quote The Fix it solution described in this section is not intended to be a replacement for any security update. We recommend that you always install the latest security updates. However, we offer this Fix it solution as a workaround option for some scenarios.
Quote Note This is a "FAST PUBLISH" article created directly from within the Microsoft support organization. The information contained herein is provided as-is in response to emerging issues. As a result of the speed in making it available, the materials may include typographical errors and may be revised at any time without notice. See Terms of Use for other considerations.
14-04-2014 8:58 PM
The fix is to install LibreOffice.
14-04-2014 9:06 PM
That said
What if the businesses / student(s) et al has already payed (extortionate fees) for the licenses
Or they do not want another suite taking up valuable room on their machine(s)
14-04-2014 9:48 PM
Get rid of the broken one to make room.
14-04-2014 10:49 PM
And then loose revenue on the costs of the unused license fees
Are you mad
Are you mad
14-04-2014 11:17 PM
It's a zero cost option.
You won't need to waste money on future "upgrades".
