Windows fertilizes!
Luzern
Fixes: 9
Windows fertilizes!
I could have titled the thread differently, but I'm a gentleman! Every evening my name is in lights!Grin
A few weeks back I'd noticed that several files and folders had duplicates, which I had not knowingly created. Having time just now, I used a duplicate finder, and shockingly there is a plethora of duplicates upwards on exactly the same paths.
It seems that Windows has included a muck spreader in my computer, but is there another explanation?
ideas, why the dups have arisen?
35 REPLIES 35
VileReynard
Fixes: 20
Re: Windows fertilizes!
Have you checked whether you have many files in /tmp or /temp or similar? Cheesy
Browni
Aspiring Hero
Fixes: 60
Where are these files located? Windows often uses symbolic links to files and some duplicate finders aren't smart enough to realise that!
rongtw
Fixes: 12
Quick access and one drive sometimes add duplicate folders Sad
i have both off
Luzern
Fixes: 9
Files were ordinary pics and docs, and as said were together in expected locations.
Luzern
Fixes: 9
I'll have to neuter QA and OD then! if they're such a breeding nuisance!Ticked_off
Oldjim
Resting Legend
Fixes: 63
Luzern
Fixes: 9
Oldjim
Resting Legend
Fixes: 63
I am probably missiing something here but they are two different file names
What is creating files every month
Luzern
Fixes: 9
No, you're not missing anything, but there are others which are perfectly identical. It's tired old eye syndrome that struck.
Champnet
Aspiring Hero
Fixes: 11
Simple check - change the name of one of the files and see if the other half of the pair changes too.
If so  @Browni  is right with the Symbolic Links.
VileReynard
Fixes: 20
Or more likely you get a broken symbolic link - you need to hope that you have a hard-link.
Luzern
Fixes: 9
I altered the original one of a pair by addition of a capital letter to the main body. The "duplicate" remains unchanged. Probably a useless move but I also did a restart after the name change.
VileReynard
Fixes: 20
I thought Windows files are not case-sensitive or is that JUST DOS?  Grin
Its not, but Windows Server 2008+ has the option to enable this for NFS mounts.
