Windows backup using nfs?
VileReynard
Seasoned Pro
Fixes: 10
I have a nfs NAS server, which I use for backups of my Linux PC's over wireless Smiley
I am saddled with two Windows laptops - one a 32 bit XP thing and the other a 64 bit Windows 7 thing Smiley
Is it:-
  • a) possible to download a free windows nfs client
  • b) (more difficult) find a method of just backing up user data - I'm not interested in installed software, although user etc settings would be nice.
Fixes: 62
Re: Windows backup using nfs?
For user data aka My Documents or indeed any other folder on the hard drive I use SyncToy but I am not sure whether that will work with a NAS server (it certainly works fine over a network)
Fixes: 49
VileReynard
Seasoned Pro
Fixes: 10
That would sound ideal - except that M$ seem to have made a command line interface a feature - only available if you pay extra for Windows 7.
They also say that it won't be supported in future - http://www.microsoft-watch.com/content/operating_systems/its_the_end_of_the_line_for_microsofts_serv...
I should say that ideally I would like to use rsync as wireless gets a bit slow for large files!
Maybe I can try installing Ubuntu via the Windows install lash-up - "Wubi"
Waldo
Quote from: A
DeltaCopy might be worth investigating.
VileReynard
Seasoned Pro
Fixes: 10
Thanks - I shall give it a bash - it says
"NOTE: If you have an "rsync" daemon running on Linux/Unix/BSD or any other platform, DeltaCopy client will successfully connect to them." Smiley
VileReynard
Seasoned Pro
Fixes: 10
DynaSync - not tried as I found a much better solution Smiley
I loaded Ubuntu onto Windows 7 using Wubi - a Windows application (had to use a 32bit version to get web plugins to work properly).
This gave me almost native Ubuntu - essentially just a NTFS file system to go through...
So I could use nfs and rsync as normal.
I used it to backup Windows users Windows user folders Smiley
There was a lot of M$ bloat though.
