Windows & Itunes
nigel1971
Windows & Itunes
Is there any issues with plusnet and downloading music from itunes? my connection seems fine but getting music is taking mins instead of seconds. i've contacted apple support but their suggestion it could be an isp issue.
2 REPLIES 2
nanotm
Re: Windows & Itunes
surpised they didn't tell you it was a windows /router issue and you needed a mac /airport.....
bonjour protocol and their servers will be the two most likely problems, run a wireshark capture whilst your doing a download and see what priority your music files are getting, if you find its in the wrong category then ask plusnet to fix it, although as I said its likely just their servers not giving the music out fast enough
Fixes: 1,481
Could be related to https://community.plus.net/forum/index.php/topic,143308.0.html
