Windows XP WiFi question
- Windows XP WiFi question
08-09-2010 8:29 AM
Going crazy over this one...
Where have microsoft hidden the channel numbers, I'm trying to configure a router to a free channel and I can't see which ones are in use.
5 REPLIES 5
Re: Windows XP WiFi question
08-09-2010 8:34 AM
This little app might help with your quest http://www.metageek.net/products/inssider
08-09-2010 8:49 AM
That worked great, thanks.
Incidentally it looks like the "BT homehub" I'm setting up for my boss reports everything as channel 1
08-09-2010 10:40 AM
Must be my "I`m being a bit dim" , day, for me....
I downloaded and installed that inSSIDer but can`t find any .exe or shortcut to it....
so how does it work.....?
08-09-2010 1:43 PM
on my XP went to start - all programs, at the end of the list metaGeek folder - Inssider with a red # icon
08-09-2010 2:25 PM
Thanks Pierre.... found it that way... and it is working..... looks very pretty...! I can watch that when there is nowt on the tele ! ! ! !
