Windows Update
- Windows Update
- « Previous
- 1
- 2
- Next »
Re: Windows Update
18-04-2008 6:43 AM
Both machines run; Vista Home Premium.
Re: Windows Update
18-04-2008 8:12 AM
Quote Strictly speaking, Vista users who are staying up-to-date with security patches from Redmond don't have to install this update, as Service Pack 1 includes all of the security patches Microsoft has released for Vista since first shipping the operating system more than 14 months ago
is from
http://blog.washingtonpost.com/securityfix/2008/04/windows_vista_service_pack_1_n_1.html?nav=rss_blo...
it may answer some questions.
I think God's contribution may have been relevant.
Quote As I understand it the SP1 update looks at your machine and only downloads what you need which varies from PC to PC, so I guess the update system isn't geared to tell you how much of the subset it is supplying and just reports the size of the complete file.
Re: Windows Update
18-04-2008 8:28 AM
"Windows Update will detect drivers that Microsoft knows may be problematic when updating to SP1 and will not offer the service pack until an update has been installed" - Taken from this article.
This is because of this problem which ocurred at the start of the SP1 roll out.
Windows update will detect if you've one of the problem drivers on your PC and will not offer service pack one as an automattic update until the problem with the driver has been resolved.
You can, however, manually download and install the service pack and then re-install the current driver for the problem device!
Re: Windows Update
18-04-2008 10:18 AM
"Windows cannot continue because some drivers are not up to date" "OK?"
and of course, it has to be OK, cos you can`t get rid of the box any other way, yet you are blissfully unaware which is causing the problem, and can`t solve it either !
Re: Windows Update
18-04-2008 10:31 AM
If you manually install it, the first you will know is when your drivers don't work - no boxes, no warnings!
If you use Windows Update you'll not even be presented with SP1 as an update if the specific drivers are on your PC until the issues are resolved (apparently it's an issue with the way SP installs and not the drivers themselves, the drivers will work if you reinstall them after you've installed SP1).
Re: Windows Update
18-04-2008 10:58 AM
Or is this part of the " Vista is designed to annoy"?
Re: Windows Update
18-04-2008 11:15 AM
If your PC doesn't use one of the affected drivers then you'll be offered SP1 via Windows Update now.
I don't think it's a case that you have to update drivers yourself to get SP1 - it's just a waiting game until Microsoft release and install a fix (either the SP will be patched or you'll get new drivers via Windows Update).
If you know what you're up to and have one of the affected drivers you can install SP1 and then re-install the current driver or update to newer one (if it's available).
A typical Microsoft experience!!!
Re: Windows Update
18-04-2008 12:31 PM
a) windows vista sp1 won`t load because of the "defective drivers"
b) windows vista sp1 won`t tell me which drivers are "defective"
Hence the analogy to "rock" and "hard place"
If windows wont tell you what is wrong, then how can you fix it ?
Re: Windows Update
18-04-2008 4:04 PM
Re: Windows Update
18-04-2008 4:33 PM
- « Previous
- 1
- 2
- Next »
