Windows Phone App for Heart Monitoring... specifically E.C.G
- Windows Phone App for Heart Monitoring... specific...
- « Previous
- 1
- 2
- Next »
Re: Windows Phone App for Heart Monitoring... specifically E.C.G
04-09-2015 9:39 PM
second link on (edited) post says it is windows phone app.
Quote from: shutter @ Mook..... that is the one I was referring to in my original post.....
@w23 First one is Android
Second one is Iphone...
I have WIndows phone... !
I'd re-post it but using a phone to post, sorry.
Call me 'w23'
04-09-2015 9:54 PM
Ah yeah, but...... it is only the software for the gismo that you need to buy from the 3rd linky, by the looks of it... and that is preeeettty expensive !...
not to worry...
not to worry...
05-09-2015 8:31 PM
you could just get the Microsoft band, the primary function for that was its ability to monitor and record your heart rhythms etc although its also pretty pricy I have seen then for about £150, still its cheap if it does the job and gives you a record of whats happening even when your asleep and totally unaware of any problems.
05-09-2015 11:15 PM
I got one from Boots Accucheck £15/20 some time ago still works fine but thought would try Phone app , both are close
- « Previous
- 1
- 2
- Next »
