Anyone having trouble with the new MSN Live?
Both my sons are having problems every now and then the cpu goes to 100% and wont respond. Its only happened since they had the new msn. Both have good pc one a dual core with a gig of ram and the other with a amd 64 2 gig ram.
When the cpu goes to 100% its shows up as system sub of svchost.
Some time if they have it start with windows it will crash window son startup.
If the dont open it then everything is perfect.
Xp SP2 Nod av
[Moderator's note by Peter (PJ): Changed thread title for clarity :)]
