Windows Live Local - now Bing
- Re: Windows Live Local - now Bing
13-06-2009 10:34 AM
Has anyone else noticed that clicking on a Windows Live Local link http://local.live.com/ now brings up http://www.bing.com/maps/ and the search is rubbish.
I tried searching for my village and it didn't even come up as an option whereas the previous version had no problems and neither does Multimap which also uses Bing
5 REPLIES 5
13-06-2009 1:56 PM
[me=adiewoo]coughs[/me]
http://community.plus.net/forum/index.php/topic,76788.0.html
13-06-2009 2:39 PM
jim coughs back - not the same at all
it used to work great now it doesn't
A search for Holt, Dorset comes up with Holt near Worcester
A search for Holt, UK comes up with the above plus one near Bradford on Avon and one near Chester.
The worst part is the search window which shows this - flaming useless whereas multimap comes up with the second picture
13-06-2009 2:44 PM
Many apologies, but Bing seems poor whatever you try to use it for.
Maybe they should have called it Sing
13-06-2009 2:47 PM
Naah - bling - all show and no substance
13-06-2009 2:51 PM
Yep sounds about right
