[Windows] - Free Security Software
Midnight_Caller
Hi All
If you are reading this you are on the Internet, and as such you need Security Software for your computer, the Security Software you should have on your computer is: Firewall plus Anti-Virus at least on your computer.
Be careful of what you're downloading from the Internet.  Many sites contain viruses or hostile Java/ActiveX objects that may severely damage your system.
Warning uninstall your old Anti-Virus version first!
Do Not Run 2 Anti-Virus Programs At The Same Time
List of Security Software & Tools
System Checkup
Back To List
Firewall
Test Your Firewall
Back To List
Anti-Virus
Scan Your Computer For Virus On Line
Back To List
Anti-Dialers
Back To List
Anti-Rootkit
Back To List
Anti-Spam
Back To List
Anti-Spoof
Back To List
Anti-Spyware
Back To List
Anti-Malware
Back To List
Registry Cleaner
Back To List
Secure-Email
Back To List
Web Browsers
Back To List
File Shredder
Back To List
I will be adding more soon
Do You know of any Free Security Software?  If yes pleas post it on here!
Borty46
Re: Free Security Software
Fixes: 62
Avira and MSE - Antivirus
johpal
Regcure may be free to download and use to scan your Registry, but I believe, you must purchase a licence to use it to clean your system.
Midnight_Caller
Thanks Oldjim I have added them to the list.
@Borty46 I will have a good look at that list.
AShampoo firewall - very easy to use but there is an activation email with a number in it and this is followed up by further (frequent) sales messages from the company.
If you don't like this, use an alias or disposable email address.
Spyware - Windows Defender and Spywareblaster.
Would mention that these two are the only (free) ones that provide real time scanning (AFAIK) and that the others are scanning only.
hadden
I would say the most important security "software" is the grey wetware between ones ears.
The licence is free, but updates must be applied continually.
juliasdream
Thanks for a great list
Much of it I have or know about but one question comes to mind
Windows has its own built in firewall and most routers have a firewall as well
What use would any of the firewalls have above what I have already
I had zone alarm once but got tired of the never ending popups asking me if this or that prograM WAS OK
often I hadn't a clue what the file or program was associated to which left me in a dilemma as to wether or not to accept it
juliasdream
Heres a another to add:
Free Windows Registry Repair
http://www.regsofts.com/free_registry_repair/registry_repair.htm
More thorough than ccleaner for reg cleanup
Midnight_Caller
Quote from: juliasdream
[Snip]
Unlike Windows firewall zone alarm for example lets you know who is trying to dile home.
The popups are letting you know that a program is attempting to dile home for example.
That is the point of zone alarm.
If not sure look it up, don't just say yes.
Thank you for the link, it has been added to the list.
Can a Moderator remove the erelevant Linux questions and erelevant comments please.
Fixes: 62
Re: [Windows] - Free Security Software
[Moderator's post by Jim (Oldjim) I have split off a number of Linux based comments.
Please note that this is in the Microsoft Windows Section - any further posts relating to Linux etc or are not relevant to the topic will be removed ]
WildRose52
Good SECURITY software
user deleted
pierre_pierre
I got an e-mail from a friend in Colorado last week, thanks to AVG, it had a trojan on it, didnt get me
Fixes: 25
Quote from: Midnight
[Snip]
Would that it did!!!  It lets you know the name of the file but then you have to do the legwork identifying whether this is a legitimate process or not.
The pop-ups seem to be there mostly to impress.  I'm not impressed, just distracted.
But how the heck are you supposed to knowHuh  You either waste a ton of time trying to find out or you guess.  It's not beyond a firewall to identify legitimate processes and not bother you about them.  The better paid-for firewalls do this.
Sure, if you haven't got anything better to do, like getting on with using the computer.
Lurker
A little knowledge can be dangerous.
An uneducated person with ZA installed could easily be fooled into thinking they were protected - even if they simply accepted every request that appeared.
There often seems to be a correlation between number of 'security' programs installed and the number of issues people have.
