Windows Explorer Oddity
Fixes: 226
Occasionally I find that after performing a search using WE search function that when I click on the Folders option again to get the list of folders in the left hand pane the list is restricted to a small area at the top of the pane with only enough space to display 1 folder.
Underneath this is the blue info area. Clicking any combination of Search, Folders, closing the pane, etc. fails to reolve the issue.
Other than the above the window functions as normal and all other windows already open or opened subsequently work as expected.
Has anyone else come across this and resolved the it? Not a major a problem as I can just use another winodw but I would like to know why.
Forum Moderator and Customer
