Windows/Excel security warning on internal link location?
- Re: Windows/Excel security warning on internal lin...
22-11-2014 2:13 PM
The location of the linked file is currently C:Documents of the local machine.
This Excel file will eventually need to be accessed by others on a small network.
The warning is along the lines of an "unsafe location".
Doesn't seem to be a 'don't ask again' option.
Not sure if its a Windows thing or just Excel. My guess is Windows.
Got a feeling I'll probably have to find whoever set up the network, but maybe there's a quicker solution?
Don't pretend to understand anything about networks in this respect!
edit - this is v small LAN in office, 3 computers only.
This link gives registry change info -
http://support.microsoft.com/kb/925757
but even so, not sure how this works on a network? Fix every computer?
Re: Windows/Excel security warning on internal link location?
22-11-2014 9:11 PM
22-11-2014 11:38 PM
Its 2007.
Can't do anymore about it till Monday.
Might have to try that registry fix - but seems a bit wild just to stop a warning box (esp as it refers to a file on C:Documents!)
Folks in office wont be too happy about that probably...
23-11-2014 12:50 PM
The good news is that you can modify the settings (at your risk) via Files / options / Trust Centre. In 2007 I think it was either 'Connection file location or 'Trusted Locations'.
Even better is that with Windows 7 or Server 2012 systems you could use Group Policy to manage and control this (and many others feature) more securely. IMO well worth investing some time and effort on Group Policy to assist in keeping common things like Fonts, paper sizes etc in line as well as the security options.
Maurice
23-11-2014 2:57 PM
Quote from: IanSn Might have to try that registry fix - but seems a bit wild just to stop a warning box (esp as it refers to a file on C:Documents!)
It maybe a long way for a short cut but you have to remember that that C:\ drive may not even be yours, and with Office's ability to execute code its there to protect you so I think you should proceed with caution. I know it's tedious but you may live to regret it.
23-11-2014 4:32 PM
Yes, indeed.
Was thinking something like that.
I guess C: is actually networked. Therefore...
Doubtful folks in this office will be happy with registry edits anyway.
Will try in OpenOffice. If is ok, does that mean OO is a security risk or that it doesn't execute code in the same way?
23-11-2014 4:38 PM
23-11-2014 5:20 PM
Ha! Need to figure out why that is.
But they probably don't want to move from Excel anyway.
I'm guessing we'll have to put up with the 'unsafe location' box.
Just doesn't look good when clients want to see pic of item and get a warning everytime....
23-11-2014 5:30 PM
Sorry, missed your comments before.
Thanks, I'll look into that on Monday. Could be the answer.
23-11-2014 8:32 PM
23-11-2014 8:38 PM
Odd that on the Microsoft site there was no mention of this to any of the many queries on the same/similar topic!
24-11-2014 8:10 PM
Will post results if anyone interested in all this.
