Windows Defender - Anti virus? or not ?
shutter
Fixes: 65
Running Windows Vista Home Premium
Just checked my Windows Security Centre.... and it states.....
_________________________________________________________________________
Malware Protection        Check Settings
__________________________________________________________________________
Virus Protection        Not Found
Windows did not find antivirus software on this computer
Spyware and other malware protection
Windows Defender is actively protecting your computer
So it would seem I DO need to have a third party AV installed as well as Windows Defender...
Which I removed to try and improve my Youtube experience...  Cry
EDIT EDIT EDIT.....
The choice is AVAST at 87MB  or AVIRA at 124MB...... comments on your preferences Please ?
5 REPLIES 5
pwatson
Re: Windows Defender - Anti virus? or not ?
I'd remove Defender and install Microsoft Security Essentials
picbits
I think MSE on pre Windows 8 is AV while Defender on Win 8 and 8.1 is AV
shutter
Fixes: 65
OK... Thanks for that DomS...... ( and PW for your advice )....  That is where I got a bit mixed up then...... down loaded and installed MSE and it has just run a quick scan... all is good..!.. so lucky me ! ! ! .. Cheesy
PowerLee
FWIW: Installing MSE on Windows Vista or Windows 7 will automatically disable the original built in Windows Defender as its no longer needed.
picbits
And trying to install it on Windows 8 results in a message saying it isn't needed as Defender is the new MSE or something like that.
I use MSE on my Win7 and Vista machines and Defender on my Win8 (cough spit) laptop.
Yup - just tried to install it again - got the message :
You don't need to install Microsoft Security Essentials
Your version of Windows includes an updated version of Windows Defender that provides the same level of protection as Microsoft Security Essentials, along with other significant improvements
