Windows DVD played on a Mac
- Re: Windows DVD played on a Mac
28-12-2009 10:29 AM
I have some video DVDs which I copied using DVD Decrypter software on a Windows XP system. They all run perfectly on the Windows XP system (video_ts format). Does anyone know whether these DVDs will also run on a Mac or do they have to be reburnt into some sort of Mac format ? I know absolutely nothing about Macs and their compatability with Windows ?
2 REPLIES 2
28-12-2009 12:15 PM
The video_ts format will be fine for Macs.
28-12-2009 1:08 PM
Thanks very much for the information.
