Windows 8 security - does it need add on package
- Windows 8 security - does it need add on package
- « Previous
- 1
- 2
- Next »
Re: Windows 8 security - does it need add on package
14-01-2014 5:03 PM
If you follow the links you will see that you do to get decent protection
14-01-2014 5:09 PM
But under both 8 and 8.1 I installed Malwarebytes, Spyboy S&D (look for v1.62 as the later versions aren't as good) and CCleaner along with Windows Defender.
This setup seems to work well on the laptop without slowing it down and, as long as she does regular updates and scans, should serve her well.
Forum Moderator and Customer
18-01-2014 11:48 AM
I'm dont always fid which report helpful - but surely there ust besomething in what they are saying?
18-01-2014 12:55 PM
As the two main independent testing organisations really pan it for protection I must assume that they were looking at easy of use etc.
This may help http://www.pcpro.co.uk/news/security/364093/report-no-need-to-pay-for-antivirus
If this is the extent of their testing it isn't really very good
Quote Which? set up five computers with a variety of protection, between wholly unprotected and fully secured with the latest, paid for antivirus and firewall.
Over a month, the PCs were used to visit a variety of webpages, from reputable ones such as Amazon to malware-riddled bit-torrent sites. None of the machines became infected.
Just found this http://conversation.which.co.uk/technology/windows8-anti-virus-security-software-tops-table-microsof...
which tends to indicate that they only looked at features and not how effective it was.
Quote Stay safe and save money
This means that lazy people like me don’t have to worry about installing extra antivirus programs. And if you’re already good at keeping your computer safe, you no longer need to turn to pricey third party software. Yes, Windows 8 beat out all the paid-for software as well. If you don’t want to upgrade to Windows 8, Microsoft Security Essentials is a good bet and happens to be free too.
The security software built into Windows 8 has the right mix of keeping your computer safe from digital attacks, while also being very easy to use. It comes with lots of other handy features, such as parental controls to keep innocent eyes from seeing sites they shouldn’t. You can even manage the time your kids spend online to ensure the computer isn’t used after lights out.
It has great protection against malware, even blocking the download of malware in a zipped file. Many other packages don’t even look into zip files. Other standout features include being integrated with Outlook 2013 and auto-scanning when you insert a USB stick. It also has a strong two-way firewall that lets you set different levels of security for different scenarios, eg in a café vs at home. All of this is packaged together as part of the Windows 8 operating system.
Note that the person doing the tests is Jessica Moreton, Senior Technology Researcher with this cv
I am sorry but that doesn't fill me with any confidence about her ability to do proper tests
Quote Jessica is part of the Tech team and looks after the tablet, ebook and security software tests. She joined Which? in September 2010, and after having worked in a range of departments as part of the grad scheme, she was finally lured back to team Tech to write about exciting new gadgets. Jessica studied English Literature at the University of Warwick and is keen on books, education and dance. You'll find her writing about a mixture of these topics.
18-01-2014 11:46 PM
19-01-2014 9:14 AM
There are a number of very professional testing organisations in this field and I just don't class Which as one of them. They are a jack of all trades and a master of none
19-01-2014 11:53 AM
I have deliberately had a couple of their free by phoning their 0800 number when advertised on the TV at that time.
And some of their information is sketchy and outdated
They obviously have not got the proper testing procedures for the real world for all the products they test
And in some cases I feel as though they are biased towards some products (however it is just a feeling and not to be taken out of context)
19-01-2014 12:57 PM
- « Previous
- 1
- 2
- Next »
