Windows 8 OEM specs may block Linux booting
- Windows 8 OEM specs may block Linux booting
- « Previous
- 1
- 2
- Next »
Re: Windows 8 OEM specs may block Linux booting
26-09-2011 9:10 PM
Quote from: Heloman I've just had to buy a new box which inevitably came with Win7 OEM pre-installed.
Plenty of suppliers offer "barebones" boxes without an OS.
(Even though I do have multiple Windows 7 systems, none of them came as OEM installs.)
26-09-2011 11:54 PM
I suppose Microsoft expect the dual booters to run Linux as a VM inside Windows, perhaps?
27-09-2011 8:58 AM
Look at how long it took to turn the statistics that indicated the correlation into proving a causal link between smoking and lung cancer.
I wonder how long it will take to work out which way the cause/effect is between paranoia and Linux.
27-09-2011 3:41 PM
Maybe M$ Is getting paranoid now that Linux Is becoming more and more usable for lots and lots of people so That Is why they are locking down PC'S. Great thing Is I wont be buying one
If life gives you lemons, make lemonade.
28-09-2011 12:24 PM
And just how do you lock down out on a server?
I would imagine Microsoft is a minority in the server market.
28-09-2011 3:17 PM
That is/was mostly in place in the server market anyway, when I used to build servers for a living, we used the HP ones and they supply an install cd that gives options of what they will support on the server - at the time M$ NT/2003/enterprise etc along with RH Linux.
You COULD still install ANY OS you wanted but finding drivers for the hardware was another matter. (e.g. PCI-64 cards with 6 nics on or multi controller scsi raid cards)
- « Previous
- 1
- 2
- Next »
