Windows 8 - Browsing history - does it delete
Interested
My partner today asked why the drop down browsing history in internet explorer 8 is retainied even if you click on the delete "X" it just re-appears.
To be honest I'd never noticed this before.
Any ideas?
Fixes: 62
Re: Windows 8 - Browsing history - does it delete
It may be related to autocomplere - try switching that off as it uses the history for it's database
Interested
Thanks will try that. Found tab in internet options and will uncheck boxes will let you know how it goes.
Interested
Have disabled drop down on menu bar in autocomplete section.
Seasons Greetings/Merry Christmas.
Smiley
