Windows 8 - Browsing history - does it delete
- Windows 8 - Browsing history - does it delete
17-12-2009 10:01 PM
My partner today asked why the drop down browsing history in internet explorer 8 is retainied even if you click on the delete "X" it just re-appears.
To be honest I'd never noticed this before.
Any ideas?
Any ideas?
3 REPLIES 3
Re: Windows 8 - Browsing history - does it delete
17-12-2009 10:27 PM
It may be related to autocomplere - try switching that off as it uses the history for it's database
19-12-2009 10:21 AM
Thanks will try that. Found tab in internet options and will uncheck boxes will let you know how it goes.
19-12-2009 10:29 AM
Have disabled drop down on menu bar in autocomplete section.
Seasons Greetings/Merry Christmas.
