Windows 8 BREAKS ITSELF after system restores
TORPC
Driver and firmware updates impossible without patch
[quote=http://www.theregister.co.uk/2014/03/26/windows_8_push_button_restore_update/]Redmond's knowledge base article about the problem says “This issue occurs because a driver or firmware dependency is added to Windows 8.1. After you perform the push-button reset features, the new value cannot be handled correctly.”
