Windows 8.1
- Windows 8.1
- « Previous
- 1
- 2
- Next »
Re: Windows 8.1
21-10-2013 11:27 AM
Twice on the laptop, and once on the desktop for no apparent reason, my profile with admin privileges failed to start and I had to make new profiles.
Re: Windows 8.1
21-10-2013 1:12 PM
Re: Windows 8.1
21-10-2013 1:18 PM
, it could be a registry problem or it could've been the system crashing out thats doing it either way you have done the right thing and created a new account with admin rights
have you run the upgrade assistant
http://windows.microsoft.com/en-in/windows-8/upgrade-assistant-download-online-faq
or try automatic repair feature
http://www.techrepublic.com/blog/window-on-windows/how-the-windows-8-automatic-repair-feature-works/...
i still think it is the update?
Re: Windows 8.1
21-10-2013 1:57 PM
It seem's to be some kind of glitch with Windows 8, where randomly when you power on, all the profiles revert to temp profiles, and using restore points doesn't solve it.
The first time it happened, I didn't have a back up, and all my work accounts etc disappeared. (stupid me).
The only way to solve it is delete the old profile and create a new one.
For some reason some files on the duff profile are ruined, where as others still work.
@365 I have been playing all morning, and finally cracked it!
Yes, I tried the assistant tool, it came back as 100% compatible.
The problem was the old profiles that had corrupted.
I deleted the whole folders, run the update again, and it installed perfectly.
Re: Windows 8.1
21-10-2013 2:12 PM
Re: Windows 8.1
21-10-2013 2:18 PM
Re: Windows 8.1
21-10-2013 3:16 PM
I went into the users file, then deleted the folders of every profile except the current one, and voila, it worked!
Cheers guys.
Re: Windows 8.1
22-10-2013 7:44 AM
Quote from: Devonian @ReedRichards that's not quite true.
I cannot have met this one yet. I was thinking of the "user profile service failed the logon" error that crops up occasionally on Vista and Windows 7. But I'm glad you got your upgrade sorted.
Re: Windows 8.1
22-10-2013 6:17 PM
It appears out of know where.
I close down the computer via the shut down option.. then when I switch on the next time, I click my profile picture, type the password, press enter.. it starts to load, then instead of the usual logging on message under the picture, it says 'arranging desk top' then it starts in a temp file.
I have no idea how or why it does it, but it's done a few time now!
Re: Windows 8.1
26-10-2013 12:02 AM
Anyone else had this problem?
Re: Windows 8.1
26-10-2013 9:48 AM
Re: Windows 8.1
04-11-2013 10:01 PM
Not sure if it's the Intel or the Nvidia drivers at fault, I think possibly Intel as according to the Nvidia control panel firefox is running on the IGP (It's an optimus equipped machine)
Re: Windows 8.1
05-11-2013 7:57 PM
- « Previous
- 1
- 2
- Next »
